Old 27th March 2011, 08:12 PM
Default Roll bar stays for GRP rear tub
Hi
Can someone please tell me where the roll bar stays attach to the chassis when using the Saturn GRP tub?
Old 27th March 2011, 08:22 PM
To the rear most part of the oblong box created by the frame,I added two pieces of 25x25 and two pieces of flat plate to mount the bar on in the corners and use two bolts either side.
Old 27th March 2011, 08:30 PM
Ok thanks Flyerncle
Am I right in saying by oblong box you mean the box made of 2 pieces of 25mm box joined together, rear suspension frame?
Old 27th March 2011, 08:53 PM
Yes,the very last part of the chassis the box where the tank would go.
I put plates either side sat on two bits of 25x25 welded inside the rear box for the plates to sit on.
Hope this makes sense.
Old 27th March 2011, 09:16 PM
This is how I did mine, very similar in the way Flyerncle has described,
I used 3mm plate to bridge the end of the chassis & as you can see, used 4 bolts with nylocs underneath ( same idea as the upper roll bar mounts ), so the whole roll bar is removable after undoing 16, yes 16 bolts ...if that lot gives way I,m a gonna anyways
excuse the untidy wiring, this pic was taken ages ago.
Old 27th March 2011, 09:24 PM
Year on the photo is 1970??????
