Old 8th May 2011, 03:20 PM
davylock davylock is offline
Question Oval Steering Column Mount on Sierra
Anybody have any idea what bolts/fixings are used for mounting the Oval Alloy Upper Steering Column bracket to the CP15 Plates. The reason I ask is the elongated holes on the CP15 plates are drilled to M13, but the Oval Bracket holes are wider ( 17mm ? ). Is there need for inserts of some kind which I'm missing. In the sierra manual it just shows two nuts holding the column.
Its a non adjustable column off an '88 Sapphire by the way, Dave.
Old 8th May 2011, 04:12 PM
SeriesLandy's Avatar
Took me a while to understand where you meant. I was wondering the same thing and was thinking of getting someone to turn me up 2x tophat type inserts for the bolts to pass through. If that makes sense.
I don't know if they are really needed but would put my mind at rest.
Old 8th May 2011, 05:04 PM
Steve, that's the way I think I'll go as well, & get my mate to turn a couple up on his lathe. thanks anyway, Dave.
Old 8th May 2011, 06:52 PM
I have been wondering tooooo.
Old 8th May 2011, 08:17 PM
What did it have on the sierra, it was soooo long ago I stripped mine I can't remember what it looked like.
Old 8th May 2011, 09:06 PM
It looks like it was just two 17mm nuts that bolted on to fixed studs underneath the fascia as far as I can make out, I never had a donor vehicle, I've just bought parts as I've gone along, Dave.
Old 8th May 2011, 09:44 PM
I should know.. Taken many appart and put them back together....
Will have to have a look at one of the cars and find out.
I considerd just making some ruber bushes.
