Old 5th July 2011, 02:07 PM
croweater croweater is offline
Default Chassis welding
Hi all,
I have noted that chassis distortion when welding is a norm, so has anyone tried welding up the frame with for example, 3mm spacers under the centre section , after tack welding, then clamping down and finish welding?
This is a process used in welding light structures and long beam lengths and I was wondering if it was worthy of consideration, before setting up my chassis and perhaps having a reverse bow just like the sydney Harbour Bridge!!
Rgds
Brian
Old 5th July 2011, 02:20 PM
If the chassis is welded in the correct squence you don't get a bananna shaped chassis. You need to clamp the base rails down in about 16 places to hold it flat then weld methodicly around the rest of the assembled chassis using the heat of the welds to pull it against its self.
Old 5th July 2011, 02:24 PM
Smile chassis welding
Thanks for that.. it was just a thought that crossed my geriatric brain! Appreciate the info.
Rgds
Brian
Old 5th July 2011, 09:15 PM
Hi,
I haven't fully welded the chassis yet, but I clamped it on my table with small brackets you can find in any construction store, the one with a 10mm hole in the centre, at 30mm above the bottom plate. Then I bought threaded bars M10, and some M10 nuts. I cut the bars in pieces of 35-40mm, and put them through the bracket holes, secuted with nuts, just manually tighten. So, the lower point of the bolt is exactly 25mm above the building board, and this will hold the bottom chassis perfectly flat on the board when I'll weld... or at least it is what I expect. I have to confess that the idea is not mine, I found it on a web site, a guy who did it and was happy with the result. If it can give you inspiration, it is a cheap, easy and efficient way to keep the chassis flat when you weld.
I've tried to attach some pictures, but I don't know if it will work. If not, I'll try another way.
Cheers.
S.
[IMG]F:\Documents\Locost\Images\1erTubes01.png[/IMG]
[IMG]F:\Documents\Locost\Images\1erTubes02.png[/IMG]
Old 5th July 2011, 09:20 PM
Well, it looks that I can't attach any picture. Do you know how to do it ? When I click on "insert image", it asks me an URL. I thought the URL of the image in my computer will work, but it does not, it should be only for web site links. If you want to see the 2 pictures, send me a personal message with your email address, and I'll send them by email.
Bye.
Old 5th July 2011, 09:27 PM
images have to be fairly small file size before you can insert.... them far better to use a hosting site like photobucket where you can load up large file sizes then just copy the link into your thread
Old 5th July 2011, 09:34 PM
YES ! I found how to attach pictures to my post (sorry for the mess, I'm new on the forum).
Bye.
Old 6th July 2011, 04:37 PM
H-L-Smith H-L-Smith is offline
Could you please expand on what you mean by "using the heat of the welds to pull it against its self?"
Thanks,
Lonnie
Old 6th July 2011, 09:42 PM
Default sequence
An easy way to explain what talon is on about is to imagine building a simple ladder say with 5 rungs in it. If you tacked it all together and it was perfectly square then were to weld all the rungs on one side it would take a bananna type set, then going down the other side would not straighten it. But if you did half of one rung and went to the other side and did half of the opposing side then came back to complete the first half an so on it would minimise the distortion. Likewise on the chassis .
Old 7th July 2011, 03:12 PM
Thank you, Bob.
I see what you mean about doing too much along one side (chassis rail) and switching off as you go. How about the 3-dimensional aspect?
For example, would an expansion of that technique be doing a joint on a lower rail on one side, switching to the analogous joint on the opposite side lower rail then going back to the first side, but now doing a joint on the top rail in close proximity to the very first one you did?
I'm trying to get as smart as I can before I weld up the chassis. It would be a shame spending all this time trying to stay withing one millimeter on measurements then see the result twist by 5mm due to a poor welding sequence.
