Old 24th August 2011, 10:36 AM
brainbug007's Avatar
Default Expansion Bottle Bracket
Has anyone got a good picture of how they've done a bracket to mount the expansion bottle for the cooling system? I'm thinking a good place to put it is infront of the engine above the steering rack? Am I right in thinking that if the top of the bottle is about level with the top of the engine that's high enough?
Old 24th August 2011, 01:24 PM
Here are a couple of pictures of the bracket I made for my expansion tank. The bottle is from a Rover 200. I kept the vent inlet of the bottle slightly higher than the rocker cover to head joint therfore it is the highest point in the water system. Works fine.
Old 24th August 2011, 01:33 PM
Hmm you rover 200 bottle looks alot easier to mount than my sierra one! Has it only got mounting holes on the top? Mine's got 3 "arms" on the bottom of the bottle going at different angles away from the bottle to speak :S
Old 24th August 2011, 01:35 PM
There is a little pocket on the back near the bottom of the bottle you could put a lug into, I didn't bother. Just did the top bolts tight to stop the bottle swinging.
Another good point is that you can get the brand new, and not have all the discolouration of an older bottle.
Old 24th August 2011, 02:13 PM
has anyone else got a picture of description of how they made the bracket usnig a sierra bottle?
Old 24th August 2011, 06:54 PM
big_wasa's Avatar
big_wasa big_wasa is offline
Another rover tank,
Nowt again.
