Old 27th August 2011, 08:06 AM
Default nancy heater
Has anyone bothered fitting a heater.Not being twenty anymore I am toying with the idea of fitting a heater and was wondering if this ground has already been trodden, if so what unit is a snug fit in that tight space?
Old 27th August 2011, 08:29 AM
rpjg1975 rpjg1975 is offline
In the days of political correctness are we permitted to call it a Nancy heater?
Old 27th August 2011, 08:40 AM
Luke2842's Avatar
Luke2842 Luke2842 is offline
I've just ordered one from t7 design and am really impressed with the quality although the heater is £100 plus extra vents/pipes was debating about getting an old mini heater or something similar? This one does fit under the scuttle but may fit it in the engine bay with an intake pipe.
Luke
Old 27th August 2011, 09:09 AM
Davey's Avatar
Davey Davey is offline
I plan to fit a small heater behind the dash on top of trans tunnel. I have a small unit that was in the rear of my camper when it was a minibus. I suffer terrible cramp if my feet get cold and as I'm now over the first flush of youth I consider it a necessity.
D.
Old 27th August 2011, 09:54 AM
I think most heater matrixes with out the casing are small enough to hide some where in the chassis, you only need to have a small enclosure to heat passing air. I thought about putting one on the back of the passenger foot well/bulkhead, that way if you have any problems it's only bonnet off not dash and scuttle off. You could always make your own from copper 8-10mm fuel line if you have a radious bender and a few hours to kill. Having said that I've just had a look on fleebay and found this for not alot of money.
http://www.ebay.co.uk/itm/Micro-Heat...item2eb29cb45d
http://www.ebay.co.uk/itm/PC-Liquid-...em20bc3f dcfb
Old 27th August 2011, 11:03 AM
I would say cool but it would probably be more apt to say Warm
Quite like the look of that dainty heater Phil
Kinda wish that I hadn't skipped the 4 Triumph heater units I had sitting on the shelf out in the workshop
Old 27th August 2011, 11:50 AM
I am thinking of something, possibly using two sierra matrix, one per side.
Old 27th August 2011, 11:58 AM
TSM Locost's Avatar
Early VW polo heaters were very popular at one time as very compact.
Be Lucky, Mike.
Old 27th August 2011, 06:09 PM
How are you going to heat the top half .
