Old 15th February 2012, 09:14 PM
tonym3x tonym3x is offline
Default Anyone running a cosworth engine?
After fitting a cossie lump in my Haynes any thoughts.
I have a good pinto 205 in already gut not mechanically minded.
Just want more power!!!
Old 15th February 2012, 09:56 PM
It's just a 205 Block with a 16V head, Turbo, EFI and a T5 Borgwarner..
The Marelli Management is no problem.
I am not sure if you can use the type 9, the flywheel bolt pattern may be differenet ( can't remember ) it may be marginal anyway with 200BHP on a 4pot box.
Old 16th February 2012, 07:41 AM
snapper snapper is offline
The turbo can be a bit high and wide, the 4x4 manifold helps.
The Cossy has a hand picked Pinto block so type9, mt75 & T5 bolt straight on.
Old 16th February 2012, 08:26 AM
BTW later Escort Cars used the EEC-IV and a smaller turbo.
Old 17th February 2012, 09:15 AM
carlknight1982's Avatar
Cossie Crank has 9 bolts and the standard pinto doesnt
Roadster No 2 build
Cost to Date : £93
Old 21st February 2012, 03:11 PM
Ive been trying to find out if anyone else made a twin cam head for the Pinto block other than Cosworth - and if it's more affordable ?
Old 21st February 2012, 06:46 PM
Jimmyd Jimmyd is offline
Try searching the net for a Warrior head I believe its what you're after.
J
Old 21st February 2012, 07:06 PM
Warrior
He said he wanted a cheaper option LOL....
Janspeed also made a twincam pinto, don't bother looking for one.
