Old 22nd December 2009, 12:12 PM
Peter-C Peter-C is offline
Default Por 15
Has anyone used POR 15 to paint their chassis ? If so, does it need a primer ?
Peter
Old 22nd December 2009, 12:47 PM
dan_g8 dan_g8 is offline
im planning to por15 my chassis. you probably know this but to use por15 you need to marine clean it (or use something else to degrease & clean the metal), metal ready it, then you need an undercoat and then a top coat.
The metal ready acts as the primer by etching the metal which will make the under coat stick.
dan
Old 18th January 2010, 12:19 PM
Vedde Vedde is offline
I used Por 15 on my chassi, with the appropriate Marine Clean, and Metal Ready as under treatment. I painted it straight on the chassi without any undercoat and it turned out FAB and cheaper than a powdercoat.
/Fredrik
McSorley+Rorty+Gibbs Locost Builder
Sweden
Old 18th January 2010, 12:23 PM
Aussie Haynes Aussie Haynes is offline
POR15 IS an undercoat! It works better if it's painted over a surface that's lightly rusted. My experience is that it peels off when painted on shiny steel. It needs a top coat to prorect it from UV.
Regards,
Mike.
The 'CLUBHOUSE'
Clubman Workshop
Old 18th January 2010, 02:04 PM
GraemeWebb's Avatar
GraemeWebb GraemeWebb is offline
As I do not have a compressor can you brush paint it? If you can what sort of finish would you get.
Old 18th January 2010, 02:49 PM
Default top coat
Can you use any type of paint as a topcoat, eg ordinary household gloss.
Peter
