Old 9th February 2010, 11:04 PM
jonnyd281 jonnyd281 is offline
Default Headlight Mounting Brackets
Good Evening all,
Nearly to the point of having a rolling chassis I'm looking at the headlight mounting brackets (the oval tubing) and I am thinking can I just use some 25mm round tube instead of the oval tube.
What are your thoughts?
Regards
Jon
Old 9th February 2010, 11:42 PM
Oval tube is purely an aesthetic issue. Round tube will perform the same job and in my experience, much easier to get hold of.
Old 10th February 2010, 12:26 AM
Peter-C Peter-C is offline
I crushed some 19mm round tube in the vice, and after several practices it seemed pretty good.
I've tried to post pictures but as usual no joy.
Old 10th February 2010, 07:50 AM
Think of the Aerodynamics
Seriously though, round tube will be fine or has been sugested, if you have a vice that is up to the job you can soon make it oval
I made a small oval dolly & ovalised some 25mm round tube on the anvil block
Old 10th February 2010, 04:28 PM
Many thanks for that guys, will use some round section instead.
Regards
Jon
