Old 11th March 2010, 08:07 PM
Russ_16v Russ_16v is offline
There is no requirement at all to have a CAT fitted.
Just a requirement to pass the emissions test at that level.
But that's very difficult without a CAT .
Thank you for clearing that up guys, so im guessing that is why most start off with Pinto's / CVH's?
www.southwest-autos.co.uk
Old 11th March 2010, 09:03 PM
It's one reason,
It's also what comes with the donor
And the engine management can be easily reused without worring about the PATS security system
Old 11th March 2010, 09:32 PM
Russ,
Just get a 1.8cvh 1992 Sierra through IVA on easy emissions then it's an easy exchange up to a 2.0l Zetec on bike carbs.........175bhp for easy dosh.
I've had a drink but that's the easy and cheapest way to mega-power....
Old 11th March 2010, 09:59 PM
or quite simply you could just put a cat on it! there are some pretty nice looking stainless sports ones that you can get for round the £120 mark
must be the first person in the world to suggest that on a kitcar site
Old 11th March 2010, 10:20 PM
Thats just it Spud, its going to take me a while, and doing an engine change will end up taking me ages, so id rather try to get it through with the engine its going to stay with if its possible?
Old 11th March 2010, 10:23 PM
Make sure the CAT is E-Approved though or you could be in for a BIG Fine.
If I were putting a post 92 engine in from a cat doner then I would just fit a cat and leave it there.
Old 11th March 2010, 10:32 PM
well i work for a VW dealer so i have the use of emissions equipmemnt, so i can always have a play around and see how i get on
Old 11th March 2010, 10:35 PM
Big Vern Big Vern is offline
Hi Ash,
So this has changed since the IVA was introduced then, as the copy I have says if the 'computer' doesn't list your make of car or near equivelent (like MX-5 and eunos roadster) then it had to be taken as non cat unless engine proven to be an August '95 or later. ie a type of engine not introduced before August '95.
BV
Old 11th March 2010, 10:39 PM
Hi Russ,
as Spud has said, use an engine from a donor car, whatever engine you get , use it, then to change an engine is quite easy really, more so if you use a TYPE 9 gearbox as the zetec will bolt straight to it with a little mod, if you use a cvh for the iva then you have most parts ready for the swap to a zetec....flywheel, starter motor etc etc.......
I,ll stick my neck out here & say if you have all the parts ready...new engine etc then it,d be a weekends work to swap em over
Also, you,ll be quite surprised how "quick " the Roadster will be even when using a cvh / pinto / twinky ( dohc ), lets say you have a cvh engine with approx 80hp..... & a Roadster that only weighs approx 500 to 550 kgs .... thats quite a nice power to weight ratio
sorry if i,m messing up your plans
Old 11th March 2010, 10:42 PM
Lol thanks Andy (did you get my pm?)
Its not messing up my plan, so you guys think its going to be easier to fit a Pinto/CVH, get through the IVA then swap to a Zetec, than fit a Zetec, and try to get it through the emissions?
Did they make a pre 92 2.0 Zetec?
