Old 27th April 2010, 07:36 PM
james3004's Avatar
Default Cp23 ??? Brake line backets
where do i put the front flexi brake line brackets, i know they go on u1 and u2 but the pic in the book isn't very clear as to what side they point?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 27th April 2010, 09:36 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, If you have ally side panels you dont need the brackets you can mount them in the panel.
I think the book ones go just below the upper rear suspension bracket pointing back.
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 27th April 2010, 09:49 PM
Enoch Enoch is offline
Like wot Ray says If you are using ally panels bear in mind that you cant' just drill a hole for the pipe to exit through, even if you put a grommet on it - the IVA inspectors don't like that. If you put the bracket nice and close to the wishbone mount it's easy to extend the hole for the wishbone bracket so it has plenty of clearance for the flexi hose to come through the panel without touching it. As far as the back mounts are concerned I found it better to have them pointing up - it gives a better run to the calipers.
Old 27th April 2010, 09:50 PM
dont bother with the front ones. just drill and fix them to the the side panels
My Pictures
Old 27th April 2010, 09:54 PM
Just to clarify my post - if you use the brackets then keep em close to the wishbone mount like I did. If you are sensible though then Ash and Ray's advise to forget them and fix them to the side panel is so obvious that it's irritating
Wish I had thought of that Dooohh.
If you want to see how I did mine then go to www.deepfolly.co.uk, go to build diary part 4 and there is a photo about 2/3 the way down.
Old 27th April 2010, 09:55 PM
Oh, Ash - pigs can't fly. Not unless they have a pilots licence.
Old 27th April 2010, 10:16 PM
Don't beat yourself up .... That happens to me quite a lot too
Old 27th April 2010, 11:35 PM
james3004's Avatar
Doh! I hadn't thought of using the ally side as a bracket!!! i'll throw the other 2 in my 'scrap, but might come in useful one day' metal pile
--- James ---
Flickr Album
Old 28th April 2010, 04:30 PM
RAYLEE29's Avatar
I Cant take any credit for this as it was ash that told me at the exeter show i do still have brackets on my chassis cause i had already done them and havent taken them off yet.
Ray
1ST ALBUM HERE
2ND ALBUM HERE
Old 31st March 2011, 10:58 PM
SeriesLandy's Avatar
What have people done if using fibreglass side panels? Do you still use a bulkhead connector on the panel?
Cheers guys
