Old 22nd June 2010, 10:25 AM
Enoch Enoch is offline
When I took my 2B in for test it failed the auto brake test as it was over braked on the back. The tester saw the valve in circuit, drove it round the car park and braked hard to make sure the backs did not lock up. He then manually marked it as a pass. Having been through that once, fitting the valve seemed the obvious thing to do. The valve will not come in to effect on the test rollers.
Old 22nd June 2010, 02:06 PM
axle's Avatar
axle axle is offline
Thumbs up
cheers guys you all have been brilliant.
Regards Axle
Old 9th September 2011, 10:08 AM
axle's Avatar
Hi all
I know it has been ages, since we last talk about this thread but the input should be to the back of the car as it was with the donner car?
Cheers Axle
Originally Posted by baz-r View Post
here is how it works
its fitted angled with the input to the top/front angled to the front of the car
when you step on the brakes hard there is a little spool valve that travels uphill by enertia preventing the rear brake lines form increaseing fluid pressure
stoping the rear wheels from locking as the back goes light
so the harder you push the pedel the rear gets no pressure rise
the steeper you set the angle the harder it is for the valve to work
when your stoped and level the back should get full pressure
hope that helps
Old 9th September 2011, 11:34 AM
james3004's Avatar
On the sierra it's fitted on the passenger side front inner wing
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 9th September 2011, 11:45 AM
axle's Avatar
Hi James
I agree with you how this is fitted on sierra, but can you agree the outlet from the brake master cylinder goes to the botton of the anti brake lock?
Thanks Axle
