Old 13th August 2010, 11:34 AM
Jimmyd Jimmyd is offline
Default Ali grade and thickness Again!!
Ok I know there has been many posts in the past but as there are many answers I thought I'd ask for a show of hands.
Bodywork 1050 H14 Ali do I use 1.0mm or 1.2mm? Yes I want it to be easy worked with but I also want it to withstand minor "dings" as much as can be expected.
Fuel tank 2.0mm?
I've some leave next week and plan to collect some sheets on Monday. 8x4 sheet of 1.2mm is about £25 +VAT from a local supplier, a bargain compared to some of the old posts I've been looking at this morning.
J
Old 13th August 2010, 12:31 PM
Definately a good price,I was quoted £40 for 8x4 sheet of half hard 1.2.
Old 13th August 2010, 03:44 PM
aerosam's Avatar
aerosam aerosam is offline
No fair - I just paid 100 quid for 2 sheets of 1mm H14 1m x 2.5m
Old 14th August 2010, 09:59 AM
So I'll take that as 1 for 1mm and 1 for 1.2mm. Any other comments?
J
Old 14th August 2010, 12:09 PM
Use whatever is easiest to work with for my money Jimmy,I would use and will use 2mm for the tank .
Old 14th August 2010, 04:23 PM
15mm steel, i reckon.
Old 14th August 2010, 04:35 PM
james3004's Avatar
i hope you meant 1.5mm TT, Would be suprised if the car would move using 15mm
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 14th August 2010, 04:51 PM
No, i was thinking of an amour plated roadster for transcontinental touring
My floor is 2mm Ali tread, panels are 1mm Ali
Old 14th August 2010, 08:28 PM
aerosam's Avatar
SNAP!
I'm glad I'm not the only one using treadplate for the floor. Took forever to abrade away the treads where the chassis tubes butt up to it though.
Old 16th August 2010, 09:49 AM
Hi Jimmy
I am using 1.2mm half hard for the bodywork & used 2mm for the floor n fuel tank.
The rear panel formed a lot easier than I expected & was no trouble at all to make
The floor is well sorted, without the slightest hint of a boing when stepped on .... Probably due the the gazillion rivets used
Not saying 1mm is wrong .... Just a tad lightweight for my own personal taste.
That is a very good price on the 1.2mm alloy, talk about the " luck of the Irish "
