Old 28th August 2010, 11:02 PM
David_17's Avatar
David_17 David_17 is offline
Default Engine clerance
Started trial fitting my engine this afternoon, but having a few issues.
My reverse light switch is very close to the transmision tunnel upright of the chassis (with the gearbox aligned central with the tunnel). I can't move it any futher back as the thermostat housing touches the chassis.
I could move the full lot 2" foward, but i'm sure the futher back, the better. (EDIT: thinking about it, then my gearstick would be through a chassis tube, so that won't work)
Any tips?
*updated 7/6/11*
Old 28th August 2010, 11:47 PM
I made a recess in the top rail for the thermostat housing. This way everything fits nicely.
Bigger: http://locost.lt/download/file.php?id=351&mode=view
Another pic: http://locost.lt/download/file.php?id=350&mode=view
Old 29th August 2010, 12:07 AM
mine is exactly the same so is andys so is spuds so is dogwoods etc etc....... it will be fine don't worry about it.
My Pictures
Old 29th August 2010, 12:21 AM
David_17's Avatar
The same as mine or Alga's??
*updated 7/6/11*
Old 29th August 2010, 08:48 AM
Same as yours done 3k now and its never been a problem. As long as its not actually touching you won't have any problems.
My Pictures
Old 29th August 2010, 10:42 AM
David_17's Avatar
Ah ok. I'll make the engine mounts up today then. Cheers
*updated 7/6/11*
Old 29th August 2010, 11:16 AM
Ash & I were discussing the length of our propshafts the other night, & we were quite surprised that they are within 2mm of eachother,
So as a "guide"......if you measure from the rear diff flange to the rear edge of the gearbox housing , where the splined end of the prop goes into the gearbox....
my measurement is 625mm , & when my prop was made to measure by D&F they asked what was the total length to the gearbox oil seal inside the housing, which on mine is 17mm, so they supply a prop a little longer to ensure it goes beyond the oil seal.
So, my prop measurement is 642mm to the oil seal...
Ash,s prop measurement to oil seal is 644mm.
The measurement from the the diff flange to the rear edge of the gearbox housing is a good guide when using a type 9 gearbox. If you are concerned about the rubber plug that connects onto the reverse light switch you could always just solder the wires to the pins which would give a little more clearance to the tranny tunnel upright.
Hope this is of some help.
David....wow you really are cracking on with your build, nice one
Old 29th August 2010, 11:24 AM
David_17's Avatar
That helps alot Andy, only problem is, i only have one diff bracket at the moment :P haha
Yea, i'm doing as much as i can on my build to get it finished, can't wait to drive it
*updated 7/6/11*
Old 29th August 2010, 11:34 AM
Originally Posted by David_17 View Post
That helps alot Andy, only problem is, i only have one diff bracket at the moment haha
Ahh ok then, not alot of help then until you can mount your diff
put it this way....the pins on my reverse light switch are just a bit rearwards of that tranny tunnel upright
ahhhhh its no big deal driving it ........kidding.... I,m still grinning , keep at it, its a great moment.
Old 29th August 2010, 08:08 PM
David_17's Avatar
Had a slow day today for some reason, couldnt get motivated
Got the gearbox mount bolted into posotion and made up the exhaust side engine mount. When it comes down to it, there is only one position where everything has clerance, so in theory i should get the same measurement when my diff is mounted.
Theres a pic in my build diary below, but i'm on my phone at the moment, so cant post it on this thread.
*updated 7/6/11*
