cheers andy |
Here is my baby just finished after 3 years graft running a brand new 4.6 v8 out of range rover p38 on mega squirt. Rolling roaded at with 225 bhp and 276 ftlb at wheels. Was tempted to use a v8 in my roadster as I've cut my teeth on them but would have to be a lower spec one as I fear to much power could twist the frame.
http://www.facebook.com/photo.php?fb...837.1313470944 |
Welcome to the forum Sebby
If you upgrade the chassis tubes to 2mm wall thickness, the chassis will be more than capable of handling the power of a V8 I believe the standard chassis has been designed to handle that sort of power anyways ![]()
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk Last edited by Bonzo : 3rd January 2011 at 11:05 AM. |
Welcome to the forum, Sebby! The facebook link does not work. Is the photo public?
This link is public. Does anybody know what the standard chassis is designed to handle
http://www.facebook.com/photo.php?pi...&id=1313470944 |
~ My Build Diary - http://davesroadster.blogspot.com/ *updated 7/6/11* Best bit so far: Getting it running Worst bit so far: Cutting steel for wishbones and engine mounts. Most annoying bit so far: Generator packing up half way through welding. |
Welcome to a very informative forum Sebby
#18
Hi David that sounds like a plan drop me a pm regards when you are free
Cheers |
#19
If you're coming over on Saturday Sebby i can take you over to David_17's build afterwards, he is only 10 mins away. If he is going to be there during Saturday.
Regards....AndyH
#20
The chassis will need more bracing around the engine bay to cope with a V8 and going up to 14swg for major tubes would be a good idea. A good trick is to use offcuts of rhs in the corners where all tubes meet on the floor section...if that makes sense?
