Old 3rd January 2011, 01:31 AM
Originally Posted by K4KEV View Post
...just about any question will be answered if posted on here....especially Handandy ( he deems it as a challenge every time )
Sebby Sebby is offline
Here is my baby just finished after 3 years graft running a brand new 4.6 v8 out of range rover p38 on mega squirt. Rolling roaded at with 225 bhp and 276 ftlb at wheels. Was tempted to use a v8 in my roadster as I've cut my teeth on them but would have to be a lower spec one as I fear to much power could twist the frame.
http://www.facebook.com/photo.php?fb...837.1313470944
Old 3rd January 2011, 09:07 AM
Welcome to the forum Sebby
If you upgrade the chassis tubes to 2mm wall thickness, the chassis will be more than capable of handling the power of a V8
I believe the standard chassis has been designed to handle that sort of power anyways
Old 3rd January 2011, 10:22 AM
Welcome to the forum, Sebby! The facebook link does not work. Is the photo public?
Old 3rd January 2011, 03:49 PM
This link is public. Does anybody know what the standard chassis is designed to handle
http://www.facebook.com/photo.php?pi...&id=1313470944
Old 3rd January 2011, 05:30 PM
David_17's Avatar
David_17 David_17 is offline
Originally Posted by Sebby View Post
Hey David just read through the blog i havnt yet started mine just doing a bit research. where in teeside are you?
My builds at stockton, your welcome to pop over for a look and chat if youre passing
*updated 7/6/11*
Old 4th January 2011, 09:27 AM
Twin's Avatar
Twin Twin is offline
Welcome to a very informative forum Sebby
Twin
CSF £857.19
Twins Roadster
Old 5th January 2011, 12:27 AM
Hi David that sounds like a plan drop me a pm regards when you are free
Old 5th January 2011, 09:12 AM
If you're coming over on Saturday Sebby i can take you over to David_17's build afterwards, he is only 10 mins away. If he is going to be there during Saturday.
Regards....AndyH
Old 5th January 2011, 12:36 PM
fabbyglass
The chassis will need more bracing around the engine bay to cope with a V8 and going up to 14swg for major tubes would be a good idea. A good trick is to use offcuts of rhs in the corners where all tubes meet on the floor section...if that makes sense?
