Old 29th March 2011, 08:18 AM
mikemph mikemph is offline
Default Chassis measurement for rollcage
Could some have a look at the book or measure chassis for me.
I need to know the measurement from the centre of the rear rollbar mounts to the chassis rail second one forward from the rear of the base
http://m1kemph.wordpress.com<---- build blog clicky
Check us out on facebook. Hamlet Engineering Services limited
Old 29th March 2011, 08:36 AM
Hi Mike,
Not 100% sure which dimension you need, but think it maybe the measurement thats on page 38, fig 4.8, this shows 1385mm from the rear face of BR12 to the forward face of BR10, but then need to add the 151mm (lean back angle of seat back rails) then add on the 80mm of the roll bar mounting plate center point. But then subtract 25mm of the SB2 rail which the roll bar mounting plate CP3 or CP4 sits on top of.
like said, not sure if thats the dims you need? ( the above dims were taken from diagrams in the book & not from a chassis)
Old 29th March 2011, 12:12 PM
That is fantastic.... Just what I was after.
One more thing... Do you have the height of the rear shock mount/rollbar mounting face
Old 29th March 2011, 12:23 PM
550.6mm to the roll bar mounting face
p43 fig 4.15
Old 29th March 2011, 12:44 PM
fabbyglass
Forget the 0.6 bit it's fabricating not cnc machining....
Old 30th March 2011, 12:56 PM
One last thing.... What is the height of the upright in line with br10...floor to top rail. Really should bring my book to work with me lol
Old 30th March 2011, 04:20 PM
U3, U6 , U7 & U8 are all 305 mm long and set on a 25 mm tube with a 25 mm tube on top, so I think 355 mm is the number you are looking for.
