Old 20th April 2011, 12:15 PM
Default Roll Hoop Back stays and cross brace.
Do the Roll hoop back stays and cross brace have to be made from CDS?
I will be mounting my seatbelts lower down towords the diff area and not on the cross brace.
Anyone got a good site for cutting templates for round rube?
Old 20th April 2011, 12:27 PM
cornishmaid cornishmaid is offline
You would be better to mount the belts to the top chassis rail rather than down inside the boot area.
Old 20th April 2011, 01:00 PM
They will be mounted at an appropriate location that does not require protection for MR IVA. Top rail or lower will be worked out at a later date.
My belts have a long single atatchement so I have a lot of variance on where they can go.
Old 20th April 2011, 01:15 PM
No requirement for roll bar so mounts should comply with IVA requirements.
Old 20th April 2011, 03:47 PM
Do they not have to be above your shoulder height?
Tubemitre was a program a lot of people have mentioned previous.Dunno if its relevent for what you want though.
Old 20th April 2011, 07:00 PM
the cros brace will be above shoulder height with the belts running over them. The location point will be elsewhere.
Old 20th April 2011, 08:27 PM
John.W John.W is offline
Does the roll bar have to be made out of round bar or can it be made out of 3 pieces of 50 x 50 box tube cut and welded to form the U shape?
Old 20th April 2011, 08:55 PM
brainbug007's Avatar
Personally I used CDS as I found it easier to source off ebay than ERW that had thick enough walls (3mm+). I got 2.8m for about 30 quid including delivery which didn't seem that bad and would cover the braces and cross section. I would think making it out of 50x50 would be a bad idea as surely the welds wont be strong enough to hold in the event or a roll?
Old 20th April 2011, 09:07 PM
Thats a good point to raise, & easily overlooked,
I,m not sure of the precise wording in the IVA manual but the belts/harness are not supposed to pull directly downwards from the shoulder, as it may be possible in an impact that the force of the impact could break your collar bones .
Sounds like TT has this covered tho by having the webbing of the harness running over the top of the roll bar center brace
Thats the reason I waited until I had my seats before welding the center brace into position so that I could get the seat/shoulder/brace bar height to the correct position.
Old 20th April 2011, 09:12 PM
Surely having the belt so close to moving parts like the drive shafts is rather dangerous? Ours are fitted to the top rail and are rather expensive willans belts.
