Old 23rd April 2011, 11:35 AM
Deanno's Avatar
Deanno Deanno is offline
Default Dash Sizes
Below is a picture of a dash similar to the one i'm thinking of and want to make a prototype befoe hand.
as I have not done the chassis yet but have the scuttle I was wondering if people have dimensions similar to the ones i'm looking for.
Many Thanks
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 23rd April 2011, 10:26 PM
If you look at the link below, my dash is just that shape. I'm on holiday until Wednesday, but when I get home, I can take some measurements for you.
Adrian
http://i1234.photobucket.com/albums/...e/dabcd8cd.jpg
My Build Pictures:
Old 24th April 2011, 11:28 AM
Deanno's Avatar
cheers Thank you very much.
Old 6th May 2011, 06:37 PM
Deanno's Avatar
Does anybody have these measurments?
Old 6th May 2011, 07:27 PM
When I made my dash out of MDF. I just offered it up to the car and took some measurements. Made a cut then tried it back on the car. Repeated this until it fitted. Took half a day to make it. Your better off waiting until your ready to fit a dash
Old 7th May 2011, 06:06 PM
David_17's Avatar
David_17 David_17 is offline
That dash looks familiar
Theres some pictures of it finished in my blog below (just got the gauges)
Will measure it for you tomorrow.
*updated 7/6/11*
Old 7th May 2011, 08:33 PM
Deanno's Avatar
cheers your a star.
I just went mad looking at dash Layouts on locost builders.
thats not my final choice i'm going for a layerd look.
Old 8th May 2011, 05:48 PM
Wynand's Avatar
Wynand Wynand is offline
I went for a simple dashboard on my 442 chassis. Panel is 9mm Marine Ply and in the picture it only has a sealer coat on. Will eventually have about 7 coats of varnish sanded between layers for that glossy Jag look. A cubbyhole will be still be fitted.
BTW, the instruments are gold rimmed VDO Heritage Gold Series units with classic black on ivory faces
Wynand
http://5psi.net
Old 8th May 2011, 06:15 PM
Deanno's Avatar
fair play look very nice.
