Old 15th May 2011, 08:06 PM
Andy_B Andy_B is offline
Default Looking for a Banjo fitting
I am on the look for a Banjo fitting for my new fuel pump..the outlet is 12mm and i am using 10mm hose...i can find plenty on the bay for 8mm hose but nothing for 10mm...i know i could join to hoses but thought it would be better with as less joints as possible...anybody got any links ??
BTW its a 2.0 injection setup
Old 16th May 2011, 01:22 PM
Make of fuel pump?Are you sure its 12mm metric not npt etc.
Internal or external thread?
www.europaspares.com
www.rallydesign.co.uk
www.burtonpower.com
Old 16th May 2011, 03:06 PM
www.burtonpower.com
This is a link to the pump
http://cgi.ebay.co.uk/SYTEC-LINE-FUE...item5d2ebb9a68
Old 16th May 2011, 10:42 PM
KAMBO KAMBO is offline
are you sure it's a metric fitting ?.....could be a bsp
Old 17th May 2011, 12:18 PM
SeriesLandy's Avatar
Could you not change the banjo stub for a push on fitting if you can't find the right size??
Old 17th May 2011, 12:25 PM
Theres a thought....the stub looks to have a spring of some sort in it ...so i was a bit weary about removing it incase it went POP ...do you have any idea what its for ?
Old 17th May 2011, 12:54 PM
In the pic it looks like its got 2 outlets, one where the screw thread is and one where the holes are for the banjo. Ive not seen one like it. Normally the bolt has a channel down the centre and a hole coming out the side.
Old 17th May 2011, 08:58 PM
rich's Avatar
rich rich is offline
that looks like a mk1 golf fuel pump
hmmm i wonder
Old 4th June 2011, 05:53 PM
Locky Locky is offline
Take it to a company like BSP or Pirtek etc, a decent hydraulics firm should be able to sort you out.
If it has breasts or wheels it will give you problems.
Planning Stage
Old 4th June 2011, 06:08 PM
I did....they (pirtek) couldnt...think they were a bit bamboozled with what i needed...i have ended out sorting a 1/8th NPT to 10mm hose outlet from Europa parts....hopefully that will do the trick !!
