Old 1st June 2011, 03:04 PM
rpjg1975 rpjg1975 is offline
Looking good there andrew, well worth the effort. Will go like hot cakes i expect. Just gotta see if i can fit one to an ally back end when i eventually get to that stage. Well done and keep up the good work
russ
Old 1st June 2011, 06:37 PM
Jimmyd Jimmyd is offline
Good job Spud.
Don't take this the wrong way but you should correct the discription on the website, "to prevent are circulating in diff" now I know it's "air" but somepeople can be an ar**.
J
Old 1st June 2011, 08:36 PM
shh120m's Avatar
shh120m shh120m is offline
looks awesome, il be having one, once iv got a bonnet!
Old 2nd June 2011, 09:40 AM
Originally Posted by Jimmyd View Post
Good job Spud.
J
Cheers Jimmy, the error of my spelling has been corrected.
BTW "discription" is spelt Description....... Couldn't resist it.
Took the car out last night and it seems to work as intended, the car seems more stable at higher speed and certainly pulls better from 60 to 100mph - quite noticably, and braking at speed is a bit more stable. Can't speak about downforce but it wasn't really intended for that will have to take it on the track - next week hopefully, Teesside track booked for race car setup......
Don't really want extra grip on the rear though as there is already plenty and would have to increase front quite a bit to re-balance the car.
Regards....Andrew
Old 2nd June 2011, 09:57 AM
Obviously the 60 to 100 test was on a private road as you wouldn't possibly be doing that speed on public roads officer!
Old 2nd June 2011, 10:36 AM
Sorry officer i meant to put kph.......
Old 2nd June 2011, 11:07 AM
cornishmaid cornishmaid is offline
How would the open sides affect turbulence? Would it be an easy thing for someone at home to fill in the sides if it requires it?
CM
Built February 2009 using Mx5 components.
Old 2nd June 2011, 12:06 PM
bobbyh bobbyh is offline
have you got a flat floor under the engine as this is another place that could give a not so nice air brake.
Old 2nd June 2011, 12:18 PM
CM
If you read the description M it mentions the open sides and some people may prefer to fill them in depending on individual taste and pieces cut from side panels could be used. Tried mine last night and all was fine, it may circulate in from the sides a bit but it's 95% better than it was. Certainly more stable at speed since there is no air blowing around in the rear area.
Bobby the engine bay under floor is open but this could be covered in ali depending on peoples choice, the tray is not really to provide ground effect but mainly to enclose the rear area.
Andrew
Old 2nd June 2011, 12:20 PM
shh120m's Avatar
You wouldn't want to get air Bourne on the crest of a hill with a flat plate under the engine bay, remember all those old f1 cars flipping over backwards?
