![]() Good job Spud.
Don't take this the wrong way but you should correct the discription on the website, "to prevent are circulating in diff" now I know it's "air" but somepeople can be an ar**. J |
![]() looks awesome, il be having one, once iv got a bonnet!
A few build photos... www.photobucket.com/ntsengineering |
![]() Quote:
BTW "discription" is spelt Description....... ![]() Took the car out last night and it seems to work as intended, the car seems more stable at higher speed and certainly pulls better from 60 to 100mph - quite noticably, and braking at speed is a bit more stable. Can't speak about downforce but it wasn't really intended for that will have to take it on the track - next week hopefully, Teesside track booked for race car setup...... ![]() Don't really want extra grip on the rear though as there is already plenty and would have to increase front quite a bit to re-balance the car. Regards....Andrew
![]() Obviously the 60 to 100 test was on a private road as you wouldn't possibly be doing that speed on public roads officer!
![]() Quote:
![]() How would the open sides affect turbulence? Would it be an easy thing for someone at home to fill in the sides if it requires it?
CM
Built February 2009 using Mx5 components. |
![]() have you got a flat floor under the engine as this is another place that could give a not so nice air brake.
![]() You wouldn't want to get air Bourne on the crest of a hill with a flat plate under the engine bay, remember all those old f1 cars flipping over backwards?
![]() would probably suffer from overheating.... all that hot air has to go somewheres, both from the rad and block and possibly intercooler
![]() Quote:
Bobby the engine bay under floor is open but this could be covered in ali depending on peoples choice, the tray is not really to provide ground effect but mainly to enclose the rear area. Andrew
