Old 29th May 2012, 06:33 PM
tkpm tkpm is offline
Default Which Fuel Pump
Just a quicky,
Nearly finished everything on the fuel side of things except for a fuel pump and fill cap.
What sort of fuel pump am i looking for, i'm running a standard set up 2L Pinto with twin weber 40 dcoe's.
I'm getting very close to turning my engine for the first time in 2 1/2 years.
Thanks inadvance
Terry
Old 29th May 2012, 06:50 PM
Hi Terry....I thought the pinto's had a mechanical fuel pump fitted to the engine.
Old 29th May 2012, 07:53 PM
They do but they aint that good at keeping a constant pressure, im blanking mine off and am looking at installing one too the rear, one thats rated for fast road car. Cbs and europa spares do them for whhat seams to be a reasonable price
Old 29th May 2012, 11:27 PM
I'm blaking mine off to, what i need to know is what sort of PSI rated pump i need.
Terry
Old 29th May 2012, 11:50 PM
My choice would be the facet http://www.jjcraceandrally.com/Produ... =Fuel%20Pumps
Also I would include regulator with a return to the tank. I ended up with all this on a twincam escort years ago that had twin 40s. It stopped it flooding and helped with the fuel boil from under bonnet heat. http://shop1.actinicexpress.co.uk/sh...___Regulators#
Old 30th May 2012, 07:00 AM
Wynand's Avatar
Wynand Wynand is offline
Any good quality low pressure electric pump should be OK with carbs
Wynand
http://5psi.net
Old 31st May 2012, 07:36 PM
somthing like this http://www.rallydesign.co.uk/product...58f81ikg4o2be1
there is higher pressure types if you need it
