Old 25th June 2012, 08:40 PM
BenBrooks BenBrooks is offline
Default headlamp brackets
anyone got any offcuts of oval tube and 45 dia tube for making the headlamp brackets with?
Old 25th June 2012, 09:44 PM
I have found that the old type plastic cheap chairs that are used in canteens etc have oval steel legs which is ideal for the headlight brackets.
Old 25th June 2012, 11:38 PM
will_08 will_08 is offline
Ive just squeezed some round tube like others on here, not turned out so bad!!
Old 26th June 2012, 12:02 AM
tkpm tkpm is offline
I used some oval tube off an old shopping trolley that i retrieved from a ditch.
I even use the castor for build dolly, which is now been used by Baz-r
Terry
Old 26th June 2012, 12:32 AM
I just used leftovers from top wishbones, don't see what's the big deal with the oval profile.
Old 26th June 2012, 11:48 AM
Same here-I salvaged the old pipe when we had a new gas meter fitted
I know, I know
Old 26th June 2012, 02:07 PM
i managed to blag myself some tubing today from school. i might try and crush it to oval in the vice but if it looks rubbish then i'll just keep it round.
Old 26th June 2012, 02:13 PM
motomaniac motomaniac is offline
wouldnt crushing it , weaken it???... just a thought...
Old 26th June 2012, 02:19 PM
i think others have crushed it (or squeezed it gently?). how strong does it need to be really
Old 26th June 2012, 03:10 PM
back support off of an office chair for me. and some old brake caliper pistons for the lamps to bolt up to.
