Old 28th August 2012, 03:23 PM
Default Bonnet catches
I bought 4 rubber bonnet catches from Kitspares, and one of them has already failed... The others also show cracks...
http://imgur.com/a/DwJMc
Old 28th August 2012, 03:55 PM
Alga its called cheap indian rubber. The trouble is I dont think you can buy anything else, this cheap crap has put the quality producers out of buisiness.
Old 28th August 2012, 04:25 PM
SeriesLandy's Avatar
Sounds like my rally design maxi balls. Never seen the light of day, been in the garage about 3 years and already cracks all over them.
What about the metal catches with the springs, (old caterham style)?
Old 28th August 2012, 05:00 PM
Cheap? At 16 quid a pair it's hard to consider them cheap!
Maxi balljoints are a different matter -- they might have been produced 25 years ago, so it's understandable that the rubber has lost its qualities.
Old 28th August 2012, 05:26 PM
Try ttp they supply for commercials , I have never had any issues with their stuff.
http://www.truckandtrailerproducts.c...-long?cPath=21
Old 29th August 2012, 10:39 AM
Has anyone tried putting hinges on their bonnet as an alternative to removing it each time ?
Im finding it's not always practical to find somewhere safe and suitable to put the bonnet when it's off. No problem at home usually but quite hopeless at the side of the road in windy conditions if you just need to pull over and tweak the mixture or idle speed etc.
Old 29th August 2012, 11:31 AM
I bought the Westfield bonnet fitting kit,not cheap but seems a neater solution & very comprehensive. I have used the rubber type catches before & found that at speed they start to let the bonnet lift!
Old 3rd September 2012, 09:54 PM
What does the Westfield bonnet fitting kit consist of ? Does it differ from the standard Roadster way of doing things ?
Old 4th September 2012, 07:45 AM
Wynand's Avatar
Wynand Wynand is offline
Check this link out - 4 pictures of yellow car on bottom of page. Im going the same way with my build, but looking for some nice hinges now...
http://www.locostusa.com/forums/view...hp?f=23&t=9328
Wynand
http://5psi.net
