Old 15th November 2012, 06:24 PM
Richard Dryden Richard Dryden is offline
Question battery
What size battery have people put on there sierra based builds?
Richard
Just keep going we will get there in the end.
Old 15th November 2012, 06:30 PM
mgglep's Avatar
mgglep mgglep is offline
I use a powervamp pv25 racing battery
My Build pics
Old 15th November 2012, 06:33 PM
Someone a little while ago recommended these to me, I've not had chance to look at them yet so cant say good/bad but apparently they come in very small sizes.
http://www.braillebattery.co.uk/
Old 15th November 2012, 06:44 PM
Default .
Sorry to clarify I meant cranking capacity
Richard
Old 15th November 2012, 07:43 PM
jps jps is offline
I'm planning to use the one from the donor unless someone comes along to tell me that's a really bad idea?
Old 15th November 2012, 07:46 PM
Default .
Yeah that was my thoughts also jps, however my donor did not come with a battery so was just wondering what size to go for.
Richard
Old 16th November 2012, 12:09 AM
I got a 40Ah Japanese form factor Varta, it's perfectly sufficient, cost me about 40 pounds, and weighs just 10 kilos.
Old 16th November 2012, 09:17 AM
IIRC the pintos are real hungry on batts and I needed 700+ CCA to start a lowly 1.6 so choose carefully Richard.....I tend to get all of my batteries from North East Motor Salvage at Peterlee for£15-£20 and that is checked with the hot wire type testers.
Old 16th November 2012, 06:14 PM
It's not like you'll ever have to start it at -15°C. And small batteries at normal temps perform like huge batteries at winter lows. IIRC Pinto's starter was 700W, not 700A. My CVH starter on a Zetec is rated at 1.2kW or 1.4kW, and I can crank for 30 secs without any sign of slowing down.
Old 16th November 2012, 08:09 PM
I tried several batteries in good nick from several cars including a couple of 2ltrs and I thought my starter was fubar (knackered ....for albert) and had it to bits twice to find nothing wrong.... when I checked I found all the batteries I tried were all 500 cold cranking amps or below ....when I wen to the local scrappy I asked for a sierra 1.6 battery ....off he went to check his battery chart then brought me a battery and tested it in front of me...took it home, put it on and away it went 1st turn of the key.....I am only speaking from experience.
