Old 9th July 2013, 06:31 PM
Originally Posted by Davidbolam View Post
I am probably going to go for their set as well as I like the way the edges have returns etc. They are also within easy travelling distance for me whereas equinox are a bit far away
Same here colchester(gillham) and Kent (equinox) just a bit far away!
Old 10th July 2013, 06:27 AM
Ben_Copeland's Avatar
Don't be put off by distance. Equinox has a very good delivery company and its top quality bodywork. You won't get better!
Old 10th July 2013, 11:23 AM
jps jps is offline
I'm really pleased with my Equinox bodywork - but collected at the advice of others just in case. I am in Essex - so the distance to AGM was one of the reasons I ruled them out and went with Equinox.
Although, somewhat ironically, AGM does I believe produce GRP for a chap in Essex who builds these: http://www.furorecars.co.uk/
I think if i'd been closer to Barnsley than Kent I would have gone with AGM myself...
Old 10th July 2013, 08:50 PM
mgglep's Avatar
mgglep mgglep is offline
I bought grp from exinox it is extremely good quality
My Build pics
Old 13th July 2013, 09:58 PM
I've used a Saturn/NTS nose cone and scuttle to use for engine and radiator clearance during my build. Anyone know if the AGM body kit is close in height dimensions to the Saturn stuff or can someone take some measurements for me?
use a merc 190E rad it fits with loads of room
Old 13th July 2013, 10:01 PM
Just for reference the Equinox bodykit is about an inch higher than Saturn/NTS so is great for taller engines and obviously normal engines too
Old 15th July 2013, 05:45 PM
MikeB MikeB is offline
When I was looking I prefered the low line look of the AGM kit and I think its a similar height to the Saturn stuff. I did post a dimension sheet at one point not sure where it is though.
The Equinox stuff is higher so as Ben says is good for taller engines. I prefer the lower look but seeing Ben's car completed it looks pretty good to.
Old 15th July 2013, 05:51 PM
Tbh I've mine up along side a Saturn bodywork. Apart from the equinox bodywork looking a million times better ;-) you wouldn't notice the height difference.
Old 15th July 2013, 07:33 PM
mgglep's Avatar
I must admit I am using Saturn and equinox bodywork on the same car and while I thought Saturn provided an excellent service which I still stand by the equinox bodywork is much thicker and rigid
I can't speak about AGM although I think I saw them at a show once and I from memory the bodywork looked good
My Build pics
Old 15th July 2013, 08:28 PM
That was my biggest problem with the saturn panels i had. Especially the back panel as it was so thin and flimsy i was worried it was going to crack the gel coat if you lent against it.
