Old 15th January 2014, 10:09 PM
Originally Posted by johnl63 View Post
https://www.youtube.com/watch?v=vUKg...0U5 9RxFKwHWq
aussie boys run you through the process
john
That Turbo Manifold design looks great, cheap and easy. I'm already browsing ebay for a TD04 turbo!
Old 15th January 2014, 10:16 PM
I had something very similar in mind for the manifold
Just been offering up the turbo to the side of the engine. It's looking a bit tight!
Old 15th January 2014, 10:23 PM
What turbo have you got again? That manifold is tiny though, surely with something like that you could make it work.
Old 15th January 2014, 10:38 PM
I didn't say I couldn't make it work
I've got a TD04L-12T off a Volvo:
Old 15th January 2014, 10:46 PM
That looks fine! There's loads of room!
What is the melting point of fibreglass again??
Old 16th January 2014, 08:58 AM
Tidy job. That you tube video is going to get us all divorced, & bankrupt ! well done for this skov, pioneering the way for us mx5 boys. I smell competition with the fix or repair daily boys !
Old 17th January 2014, 03:08 PM
I smell brown trousers
Old 17th January 2014, 07:06 PM
james3004's Avatar
Have you not got the turbo upside down in the pic john?
Mine went the other way up
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 17th January 2014, 10:58 PM
Erm sort of... but if I put it the other way round the exhaust comes out the wrong side
I have however removed the locating pegs in the housings so I can rotate the centre section round 180 degrees so it's the right way up.
Old 18th January 2014, 11:59 AM
its called "clocking" when you turn the cartridge....ideally you want oil feed at the top and drain at the bottom...drain usually goes straight into the sump. things look like they are going to be tight in there use plenty of that heat shield stuff on the back of any fiberglass near hand.
