Old 17th July 2015, 10:13 AM
NeilW NeilW is offline
Spent days cleaning up parts and blasting whatever I could, diff came up quite well.
Got the diff and ns rear upright mounted.
Had an absolute nightmare with driveshaft CV's but eventually managed to get them together.
Also got the temporary engine in place so I could check the mounts etc, inlet manifold will be removed / replaced.
New engine will be 2.0 Blacktop Zetec, I have an eaton charger that I am toying with putting on.
Old 17th July 2015, 10:49 AM
Plan of attack today is get the rear disks and calipers on. Stripped and refurbes the calipers yesterday. Bit tricky to get the circlip back in place against the spring but managed with a socket and g clamp.
Total Spent so far - £xxxxx
Last Purchase - Engine mounts, steering wheel, slave cylinder.
Old 17th July 2015, 11:31 AM
Rosco Rosco is offline
looked good mate, good bit of progress there, also what make is that scuttle?
My Build Thread
Old 17th July 2015, 11:44 AM
Thanks buddy, knowhere near as 'clean' as yours but I am quite happy working in crud...
Not sure what make it is, I got it from Porkchop on here. The rest of his stuff is Saturn, so I would hazard a guess at that.
Old 17th July 2015, 01:10 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Looking good indeed
the scuttle bulkhead is saturn same as the one on my car
Old 17th July 2015, 01:35 PM
Thanks, so much work goes in. Just a pain to upload all the pictures.
I am close to 150 hours so far...
Old 17th July 2015, 08:31 PM
Looks pretty clean to me!
Photos wise, I take the pictures on my phone then upload them from my phone to photobucket using there app, then I write my posts on an iPad and copy n paste the links from the photobucket app on the iPad, not to bad
My Build Thread
Old 29th July 2015, 11:15 PM
Well not much progress to shout about lately. Crap weather has had a knock on effect on my ability to get off my arse.
Managed to get the rear 'rolling', new bearings, discs & pads, fully assembled and rotating freely.
Moved on to the front and after several hours/days of head scratching and forum searching finally I found that I had made a bit of a cockup on the front lower wishbones - for some reason I misread the dimensions to 365 instead of 395! - bugger! - a few quick mails and Phil to the rescue.
Also managed to get my engine sorted, 2.0 blacktop, practically new, 30k on it.
Eaton m45 charger due for arrival on Friday so hopefully will have this weekend to investigate fabrication methods.
Ecu choice still needs to be decided upon, was always inclined to go mega squirt but struggling to find any local tuners who will touch it.
Old 29th July 2015, 11:50 PM
vmax1974's Avatar
For the tuning try automark at stokesley he used to tune my race car and he really knows his stuff
Old 29th July 2015, 11:59 PM
Cheers for the info, I must have called 10+ tuners and all were recommending Omex. I will give them call.
Just want to make sure we have local tuners before committing to ordering an ecu.
