Old 12th August 2015, 05:49 PM
NeilW NeilW is offline
Quick update, managed to get bailed out with the reamer - thanks to Paul (flyerncle), the wishbones however are a different story... Took them to a friends machine shop so he can re-tap the threads - Phil these were the bones I got fabbed but maybe it's possible for some contaminants to have got into the threads as my garage is a poo hole for dust/dirt and black paint.
The transit drag links are ruined as the threads look to be flattened. Luckily I have 2 more new ones.
Just to put my mind at easy the transit drag links and wishbones are m18x1.5??
Total Spent so far - £xxxxx
Last Purchase - Engine mounts, steering wheel, slave cylinder.
Old 13th August 2015, 12:21 PM
Found tap at home Neil and it is 18 x 1.5 metric.
Old 13th August 2015, 08:38 PM
swanntech swanntech is offline
Default ball joints
i thougt mine were 3/4 unf
Old 13th August 2015, 09:44 PM
Still waiting for my mate to get them tapped, he is currently off work.
Paul, I will fetch the reamer back tomorrow. If you see this in advance I will fetch the bones from my mate and bring them through, if you could take the tap to work with you?
If not, I can just leave them with my mate ready When I am back from the states next month.
Old 14th August 2015, 12:23 PM
Just saw post now Neil,just turn up we can sort it (eventually)
