Old 26th August 2015, 09:23 AM
When I got the CBS fuse and relay module I did a Coreldraw map of my wiring at full size. This was for a megasquirted MX5 engined car, but I split it up by lights and engine on their own layers so I could measure the runs etc.
Ill try and dig it out when I'm at home.
What I did when I did do my rewire was just buy large reels of black cable in different gauges and a few packs of multicoloured shrink wrap and just put the same colour at the plug ends for identification.
Old 26th August 2015, 12:51 PM
Depends on what you use for an engine and what other goodies you intend to use.
Get some seven core for the rear lights and use trailer wiring code,and a few rolls of different coloured wiring and lay it out where it needs to go and Bob's your uncle,or nearly .
Old 26th August 2015, 08:40 PM
Attached to this post is a PDF of what I did. In Adobe Reader if you click on the 'Layers' icon on the left as shown in the image file you can turn on and off layers by clicking on the eyeball icon next to the layer.
Also here is an image showing the various wires I put on the plan. they are on top of each other so you would only 'see' the top one on the PDF
HTH
Old 26th August 2015, 09:35 PM
Ianr Ianr is offline
I am adapting a stock MX5 Mk 2 loom at the moment and wish I had been able to make my own, I am sure it would be simpler - but - I am using the standard ECU which also has an immobiliser ECU and transponder key set up. I have not been able to find a complete UK wiring diagram but have got a selection of Miata ones which are different in a number of places. If I were to use an aftermarket ECU I am sure it would be relatively simple to make a loom up but not really if you want to keep costs down by using the old ECU's
Old 27th August 2015, 08:16 AM
Heres a version of a PDF where I offset all the wires so you can see all the runs on each layer.
