![]() Quote:
I can help if have any questions. Quote:
Here are the answers if you decide to proceed with Megasquirt. 1. Self-built car, Zetec Blacktop engine 2. Both 3. Bank firing works, sequential would be nice. 4. Personally, on top of standard MS I control the fuel pump, cooling fan relay, PWM idle and tach output. 5. See 1 6. Wasted spark coil pack. Can switch to COP. 7. Ford VR crank position sensor with holes in the flywheel. 8. Per their page, it's 36-1 teehth, first tooth angle 80°. 9. On the standard Ford manifold, there's a solenoid PWM idle valve. Of course, if you're not using the standard inlet, it depends. 10 - 12. You have to answer yourself. The last three questions really highlight if Megasquirt is the right choice for you. If you want to build it yourself and really understand all ins and outs, there's nothing better (Until FreeEMS is ready!). If not, probably look somewhere else. Good luck!
![]() Oh, btw, if you decide to go commercial, here's one more name to check out: http://www.vems.com/ . Heard lots of good opinions about it. Designed in Hungary!
