Old 14th September 2015, 03:15 PM
Hi Sot, Just in the process of mounting my rad like yours, I was concerned about trapped air at the top of the radiator and noticed you seem to have added a bleed valve/s of some kind to the top of rad. How did you do it without leaks or aluminium welding.
I just carefully tapped for M6 and used a rubber washer to seal against a socket cap screw. Just nipped up the socket screws not too tight. I have some 4mm Ali and I'll rivet a piece on with some closed rivets and RTV if they strip and tap that instead.
Saying that I'm not convinced now I really need them, As the water flows down and then up in that orientation, as long as you have a header above the radiator it should naturally fill up.
