Old 18th September 2015, 09:09 PM
Rosco Rosco is offline
Originally Posted by norton View Post
That's looking super, really polished. Can I ask, what's your trade? Do you work for McLaren?
Lol cheers, it's getting there bit by bit, still loads to do I think, I wish I did work for mclaren! I'm an engineer, working on cnc mills, we make aerospace and f1 parts from aluminium, stainless and titanium mainly
My Build Thread
Old 19th September 2015, 05:22 PM
norton norton is offline
Ah, so there's some work place skills that come in handy!
I guess it'll be able to move under its own steam soon...
Old 19th September 2015, 05:44 PM
Yeah a little lol, but I do make most of my stuff at home though
As you moving, yeah not far away, need some shocks and wheels, only thing is I want to get my bodywork first so I can work my wheel offset out so its sits nice
My Build Thread
Old 19th September 2015, 06:07 PM
Well more done today, made some little crush tubes for the fuel rail, also I've vapour blasted the bracket to make it look at bit more factory
Also I've started making a new gear lever, just the lower bit with the bearings in as its a bit of a bodge lol
My Build Thread
Old 20th September 2015, 05:54 PM
More done today, loads of bits and bobs to do, got my clutch cable sorted, had to make a bit at the pedal end and solder a bit on the other end, it wouldn't solder to start with, to hot I think, but got it done in the end.
Also got all my aluminium engine cradle spacers back on and tightened up.
Then went down my dads and made my air filter backplate ready for the itg filter, I got a drawing from ITG for the outside
Came out mint
Pretty much there now, just need a few holes in it for wiring, air temp and the fuel feed, also need some 3mm spacers under the trumpets to replicate what was there before as it's got orings that seal everything
My Build Thread
Old 26th September 2015, 07:10 PM
Steering rack and track rods re fitted
When I re fitted the steering shaft my break pipe was in the way so I had to make a new one
Rear discs and pads fitted
Done a bit more on my inlet, fuel rail all fitted and fuel piped up
My Build Thread
Old 26th September 2015, 07:12 PM
I removed the pins from the injector plugs ready to pass through a grommet but then decided I'm going to cut the lot and put a connector inline so it's easily removed
Also my air filter came last week and fits sweet!
My Build Thread
Old 9th October 2015, 09:24 PM
Right update time, been bitting and bobbing all week really
Rear lights temporarly mounted and wired to the front
Makeshift dash sorted so I can start to get things wiried
Battery cables done
My Build Thread
Old 9th October 2015, 09:26 PM
I'm using these terminal bars for my wiring
Toggle switches for my dash
My Build Thread
