Old 21st September 2015, 11:34 AM
NeilW NeilW is offline
Great to see another build starting. Good luck and keep posting.
Total Spent so far - £xxxxx
Last Purchase - Engine mounts, steering wheel, slave cylinder.
Old 28th September 2015, 10:26 PM
SteveH1 SteveH1 is offline
Default More toys
More toys by stephen harborne, on Flickr
anyone any tips for using one of these
Old 29th September 2015, 07:55 AM
Originally Posted by TalonMotorFabrication View Post
Always keep good blade tension it will stretch a very small amount, plenty of good quality coolant as it also acts as lube and will keep the blade sharper for longer, buy a constant pitch tooth blade 10 or 14 tpi not a vari pitch you will shear the bigger teeth off, don't be tempted to let it drop through the material too quick.
There is no coolant system on it but was gonna use an oil can to help keep it lubed.
Old 29th September 2015, 08:34 AM
I use one of these hand held manual, gravity fed, multi machine, universal coolant pumps.
Old 29th September 2015, 10:15 AM
Nice
What coolant do you use
Wouldmean i have to build a drip tray also.
How many cuts would you get from a blade
Old 1st October 2015, 08:17 AM
So im hoping to to start cutting the steel at the weekend and im using the saturn plans and i was just wondering if there are any adjustments i should make from people's experience
Old 1st October 2015, 10:19 AM
If it is the latest book it should have the updates in and they are on here if you are stuck.
Have fun .
Old 5th October 2015, 10:31 PM
So i got around to finally starting my build
and after about an hour of messing around with the the saw
i did the first cut
First cut by stephen harborne, on Flickr
Old 7th October 2015, 08:23 PM
So while posting the above post the other night the baby stated crying so i didnt get around to finishing it
Any how i didn't just do i cut and leave it
I cut all the bottom rails and the uprights and started tacking them together the only one being the problem was the 78 degree angle but after a bit of grinding it was grand
Chassis first pics by stephen harborne, on Flickr
Old 7th October 2015, 08:32 PM
So its quiet in work at the moment so i managed to get the rest of the week off and i got a few hours in the shed this afternoon.
so i tackled the front frame first of all and thanks to the handy guides worked out perfectly first time
