Old 18th October 2015, 10:45 PM
Badger Badger is offline
Originally Posted by norton View Post
Does anyone know if the book spec roll bar or, more specifically if the harness mounts are iva compatible?
Simply: No. They don't meet the requirements of either being attached at both ends or down one side.
Threaded bushes should be welded (at both ends) through the tube, and not end mounted on the surface. (A threaded bush may be attached by
its side surface to a structural component).
Here's what I did:
Old 18th October 2015, 10:54 PM
Use a piece of thick walled (3mm) square tube for the cross member and weld the bush to the rear side of that. I passed IVA ok that way. Tubing will also pass a radius test no problem.
Or weld the bushes through the round tubing supplied.
Old 19th October 2015, 11:14 AM
norton norton is offline
Hey guys, thanks for all the feedback.
Re the harness mounts I think I'll put them inside the cross tube (I understand I may need a new tube, I'll measure in a sec). Is their position ok?
