Old 23rd October 2015, 04:16 PM
SteveH1 SteveH1 is offline
Is it a bead ur looking to create to stop the hose coming off
Old 23rd October 2015, 04:48 PM
norton norton is offline
Yes that's the goal.
Old 23rd October 2015, 04:56 PM
Ok so measure the circumference of the pipe and cut a piece of copper brake line to this length
Then split the pipe along its length and push the split onto the lip of the pipe all the way around and solder in place.
Assuming its steel as i dont know if you can solder ali
Old 23rd October 2015, 05:51 PM
rather than split it grind it back on one side until you can easily push through then you can push it on and solder....that is how I got a rounded edge on my exhaust tip...... for beads to keep pipes on simply bash a piece of brake pipe or cut a strip from a copper pipe and roll it around then solder ...did it on some of my steel water pipes
Old 23rd October 2015, 06:05 PM
Smile
Yea musta been your thread i seen it on
Old 24th October 2015, 01:30 AM
Ok so, standard.
Standard facing forward.
The intended finished arrangement. This my spare inlet with the 90 degree bit chopped off.
Old 24th October 2015, 09:06 AM
Rosco Rosco is offline
Ok so why couldnt we just chuck on the inside of the tube and turn a grove in?
My Build Thread
Old 24th October 2015, 09:34 AM
The id is about 28mm. Have you any internal jaws that small?
Old 24th October 2015, 12:39 PM
Pedal box is more or less done. I need to hook up the hydraulics and test it. I also glued some this rubber flooring to the floor as it just felt like it needed it. Should dampen the floor panel too.
Old 24th October 2015, 11:30 PM
I will have a look in the morning
My Build Thread
