			#201
			 Is it a bead ur looking to create to stop the hose coming off
	Slowly tipping over the edge into madness  |
			#202
			 Yes that's the goal.
			#203
			 Ok so measure the circumference of the pipe and cut a piece of copper brake line to this length
			Then split the pipe along its length and push the split onto the lip of the pipe all the way around and solder in place. Assuming its steel as i dont know if you can solder ali
			#204
			 rather than split it grind it back on one side until you can easily push through then you can push it on and solder....that is how I got a rounded edge on my exhaust tip...... for beads to keep pipes on simply bash a piece of brake pipe or cut a strip from a copper pipe and roll it around then solder ...did it on some of my steel water pipes
			#205
			 Yea musta been your thread i seen it on
			#206
			#207
			 Ok so why couldnt we just chuck on the inside of the tube and turn a grove in?
			#208
			 The id is about 28mm. Have you any internal jaws that small?
			#209
			#210
			 I will have a look in the morning
