#231
#232
+1
If the pedal is too hard, you want to reduce the diameter of the master cylinder, not to increase it. Good job with the clutch line, it looks nice.
#233
I considered the 0.625 mc but thought that was quite a jump. Nevertheless it looks like the next available option.
#234
I remember skov having a stiff clutch problem as well. David
#235
That's interesting, I'll fire a message to furore for advice. I've used a -3 hose and m10 banjo fittings. All the moving parts are friction free so it's definitely a hydraulic issue.
#236
the banjo fittings may be your issue, try a bit copper pipe in with standard male ends before you go spending any cash.
some master cylinder to slave setups do use 10mm pipe but not on the mx5 |
#237
I don't know what the standard ones dia is but that is what I am using and clutch feels fine, and I am using a flexi line as well
My build blog here http://ianhaynes20.wordpress.com |
#238
I don't know the pedal box dimensions/pedal leverage but it's all as per the Saturn plans using a 0.7 mc.
#239
Top hose.
![]() Bottom hose/inlet. ![]() ![]() And to make this work I made up an 8mm copper line to route coolant from the cold start/fast idle valve to the water pump inlet. ![]() So asides from the expansion bottle the coolant pipes are done. I also wrapped the exhaust manifold because I felt like a tart... I've been putting off the brake pipes as they have the potential to completely cack if not formed perfectly. I can't put it off any longer though, they have to happen. My next update will likely be in a year or so's time. Last edited by norton : 17th November 2015 at 11:55 PM. |
#240
Hahaha, take your time! Lol!
