![]() Wha do u mean bend the bracket i was gonna make the u type bracket like the book
Slowly tipping over the edge into madness |
![]() I think he means like this so you're welding around the foot of an L-shaped tab... Although I decided to cut it from 5mm box section.
![]() Last edited by JasonL : 19th November 2015 at 07:39 PM. |
![]() I see well i was gonna get the 25 mm long threaded tubes and weld it to the bar then a 5 mm plate over it and weld all around that if that makes sense
Thanks
![]() What I did was make the actual bracket longer than book and fold the ends over in a long u shape and just weld a nut on instead of tubes.
![]() What he is trying to say is the bracket is much stronger if can spread the load along the edge of the box section and across the top face of it as well, you then weld effectively all six sides of the bracket. Just go on ebay buy some 7/16 UNF nuts drill an 11mm hole and weld it in place, a little tip grind the plating off the faces of the nuts first.
His brackets and mine look like this.... ![]() and I promised myself I was'nt going to post any thing today.
Unofficially rated No.1 supplier of fabricated Haynes Roadster parts by the workshop rat population. Direct email talonmotorfabrication@gmail.com Last edited by TalonMotorFabrication : 20th November 2015 at 07:05 AM. |
![]() Thanks guys
![]() Quote:
![]() Hope this will help ![]()
Sylvain Pictures of my completed Roadster https://www.flickr.com/photos/994983...7646799525542/ Build blog: http://vouchtroadster.blogspot.se/ https://caferacer-kawa-gpz-zx550.blogspot.com/ Last edited by voucht : 20th November 2015 at 08:09 AM. |
![]() That is exactly what "He" meant,Ta.
And put the bolt through plate and nut to center it before welding it.....
![]() Quote:
Sorry I have a mental block on spelling your screen name correctly as I struggle to say it.
Unofficially rated No.1 supplier of fabricated Haynes Roadster parts by the workshop rat population. Direct email talonmotorfabrication@gmail.com |
![]() Just imagine the imaginary "u" before the "n".
