Old 25th January 2009, 07:25 PM
Hi Mark
I'll see you late afternoon. 3 ish, I will try to bring up the back box too.
Visacks old yard at Devoran ( Where macsalvage was )
Old 25th January 2009, 07:27 PM
Bonzo, yes that plate would be nice to keep,what does the little badge thats below the sierra badge on your tailgate say??
sorry David, but your tale of today did make me lol
Old 25th January 2009, 07:41 PM
fabbyglass
Originally Posted by Bonzo View Post
Hi Mark
Okey doke and no...go past visacks yard to roundabout then turn left to Bissoe then right up to North Grange Ind Est...then sniff...
Old 25th January 2009, 07:50 PM
Ok Mark. No probs ill find that ok.
Old 26th January 2009, 04:11 PM
fabbyglass
Cheers Ronnie.
Nice to put a face to a name and cheers for the wheels etc.
Old 26th January 2009, 05:14 PM
Originally Posted by fabbyglass View Post
Cheers Ronnie.
Likewise Mark.
Great to meet & have a good ole chinwag.
Old 26th January 2009, 06:03 PM
jasongray5's Avatar
Ronnie you have a PM!
Old 11th February 2009, 08:01 PM
Default Strippng
Donor number 2 almost stripped.
Just the rear subframe assembly & Fuel tank to remove.
I forgot how much fun it was removing the loom (not).
Looking forward to the fun bit.
Air chisel & sthil saw are coming out to play. I may even let Bertie the burner have a coming out party.
Most of the crap is loaded in the truck. It'll all be gone by the weekend I hope.
Jas. I'll inspect the diff & driveshafts once they are removed. I will have a clearer idea as to what I will have spare.
Old 11th February 2009, 08:27 PM
Default Idiot or what !!??
I forgot to mention.
There I was pulling at the propshaft like a madman, swearing and cursing (as you do). Just could'nt get it to pull out of the gearbox.
It then hit me, it's a MT75 box & the prop is bolted on.
Fabby, I have removed the Middle box. I'll drop it up to you next time I go up the breakers.
Old 12th February 2009, 10:30 AM
jasongray5's Avatar
Cheers Ronnie!!
I made the same mistake when trying to remove the prop, it seperated in the middle Just when I was using all my might, and i ended up facing the sky in a puddle of silage effluent... Bad times
Cheers again Ronnie
