  #22
Old 12th December 2015, 04:47 PM
garyt garyt is offline
well finally made some head way with the brakes... I NOW HAVE BRAKES
after a lot of frustration with the braking system I took Silvains' advice (some one elses thread ) and mounted a remote reservoir on the bulkhead with a couple of pipes to some steel reducers at the mx5 m/c with the brake pedal back in place a few pumps had fluid through each corner, bled them all, checked pipework for leaks = none and a solid pedal too . Just need to redo the fluid level wiring and its done
measured the prop so its off on Monday to be shortened .
Hopefully I can get a bit done tomorrow as well
Gary
