#23
so went out and started attacking the 2 throttle bodies no matter what I did It still wasn't right, searched about compressor surge causing problems, so checked the bypass was working... yes popping open n shut like a good un,
Then the old fella next door came out to see if I needed a hand... he couldn't and didn't want to attempt to slide into the drivers seat and asked if it was ok to work the throttle by twisting the linkage, and guess what no running on a steady idle, clean pick up and drop back, now whats the problem ???? a badly routed throttle cable from the pedal was causing enough friction that the linkage was dragging so iffy pick up and not returning cleanly. so re did the cable checking the pedal was free and the cable was free and guess what its all behaving from the drivers seat and by twiddlingt linkage MUPPET moment still at least that's all done now
remember we are not mad just creatively insane |
