Old 24th February 2016, 11:49 AM
garyt garyt is offline
email from vosa confirming receipt of application and giving a reference #
Old 25th February 2016, 11:20 AM
Gary
I'm wondering if you could help me out as we have got the same engine. My wiring diagram is showing a second data connection under the dash OBD2. My question is Do you have an OBD2 connection under your dash as I cant find one on my loom but I'm thinking I'm missing a bit of the dash loom with this connection on. I've been reading up on this and Mazda started to fix the OBD 2 on the mk2.5.
cheers Matt
https://www.flickr.com/photos/124541083@N02/
https://haynes.co.uk/forums/showthre...=13262&page=12
Old 25th February 2016, 06:14 PM
arghhh, I don't have 2 of them, I seem to remember chopping a heap of wiring out that had one attached, and the other one had a load of abs related stuff going into it and I am pretty sure there were only a couple of wires left by the time I was done.
Sorry I cant be much more help, my mil light was on and no matter what I did it still glowed grinning like at me, so, not good practice I know, but there is a spare bulb in my tool box now . some one will probably tell me I'm not allowed to do this ... but I have
Old 25th February 2016, 06:15 PM
just in from work to find an envelope with all my receipt copies, but no build photos returned, checked emails to find " your application has been accepted, please pay" so will get them paid first thing in the morning , I guess they open at 9am?
panic, relief , excitement
Old 26th February 2016, 05:06 PM
well a very nice lady relieved me of £450 today , so iva paid for , then got an email that it is now sent to TaSS (testing and support services) for processing
Old 27th February 2016, 08:43 AM
just back from the garage and it passed the emmissions BET test, headlights NOW correctly set and was reading 95Db at 3000 revs, but that needs to be checked at 4000 my fault as I trusted my memory (must be an age thing) so will do that again later on.
On another positive after sorting my sticky throttle cable it is so much easier to drive, 2.4 rack + supercharger power delivery certainly makes her a sprightly little beast
so a spring in my step today.....
Old 27th February 2016, 10:47 AM
Best of luck with the IVA
Old 27th February 2016, 05:37 PM
thanks, I'm trying to go over as much as possible, edge trim, nut covers, things clipped down.... I think I'm getting paranoid.. lol
I guess the stress level will go up even more once I get a date confirmed
Old 28th February 2016, 06:38 PM
well put nut covers on today, trimmed a couple of edges that I found on the bottom of the headlight bracket, secured the heater/ header hoses onto the bulkhead sorted the radius on the trip button, was really worried about the viewing angles of my small front indicators so took them off and ordered a pair of '70's style chrome bulgy ones for the test so it should be ok on the 20 deg side view. ordered a new rad fan as mine looked untidy. and reset the rear brake adjusters now the handbrake holds like a good un.
So still to do; trim under dash in footwells, fit a new reverse switch as its playing up, pad steering wheel center, keep going over bits and pieces, found out I needed 2 odd size nut covers for the exhaust bracket so ordered them.
Does any one know the thread size of mx5 tre's as I have castellated nuts and would rather nylocs
Old 29th February 2016, 10:54 PM
more updates from vosa;
application released for inspection and successfully assessed.
then this one;
Your recent application has now been processed by DVSA Testing and Support Services (TaSS). If you have notified us of a preferred appointment time and date you will receive an appointment letter via email once the DVSA Testing Station has allocated your appointment. However, if you wish to speak to DVSA regarding the scheduling of your appointment please allow 3 days from the receipt of this email prior to ringing us on 0300 123 9000.
guess what I'm doing in 3 days time
