![]() So let me get this correct in my own mind so I don't get this confused. You are considering putting the main thing that creates 300+ cranking amps of 12v power in the same compartment as the item that holds and freely vents petrol vapour....carry on son.
Unofficially rated No.1 supplier of fabricated Haynes Roadster parts by the workshop rat population. Direct email talonmotorfabrication@gmail.com |
![]() Four pieces of angle to hold it in place and strap over the top to secure, foot rest in front of it to stop passenger pushing over or make foot rest the battery holder,dont forget nice thick grommets over cables and mark earth cable,also cover terminals.
As for placing battery in boot,the cable would cost more than the car to buy,look at BMW bat cables about, 13 mm thick to counter volt drop over the distance of the cable
![]() Quote:
![]() Phil, when you are my age or older then you can call me son, have you never thought of boxing in the area above the diff and mounting it in there, and have you never looked in the rear of a 3 series BMW that just happens to have the battery in the boot.
Hay man keep grounding out that workshop of yours, in my humble opinion, that's about the best thing you will ever manage to complete successfully kindest regards Arfon |
![]() Very acidic comment given the battery content of this post.....
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. Last edited by flyerncle : 2nd March 2016 at 11:58 AM. |
![]() That is me being reserved, anyone that knows me would tell that is pretty mild.
Arfon |
![]() if thebattery is in the footwell i think it needs to be in a battery box. i am putting mine in the back left hand corner of the chassis. same as where it fitted in a mx5
