hi
I'm building an mx5 roadster with my son , this weekend we put in the engine and made some dummy mounts, but do the mounts really need to be made out of 5mm steel ? It just seems rather thick ! |
With the forces that come from the engine twisting the mounts I would stick with 5mm bettersafe than sorry
Yes they do!
I accidentally made mine out of 3mm and they lasted a couple of thousand miles before one failed. ![]() Luckily I noticed before the tear got all the way to the end and my engine fell out! Last edited by skov : 4th March 2016 at 08:34 PM. Reason: Added photo |
Ok thanks - I will make them out of 5mm in the morning
I'm trying to make the sump as high as I can so will be time consuming I think ![]() |
if trying to raise the sump watch out for bonnet clearance, I used a saturn wide scoop bonnet and still have a good bit of underhang and I even tweaked the engine slightly off center.
Its the plenum and throttle body that caused the issue
remember we are not mad just creatively insane |
