Old 27th March 2016, 05:58 PM
Rosco Rosco is offline
Got a few more jobs done
The front of the car was on the floor on the bump stops so had to make some plastic spacers
Sorted a brake light switch out
My Build Thread
Old 27th March 2016, 06:01 PM
Next up a job I've been putting off for some reason, front indicators,
First up drilled a small hole to check it looked about right
I had to open some grommets up as the fiberglass is quite thick
My Build Thread
Old 27th March 2016, 06:02 PM
Glued some indicators into some carbon tube
These will push in either side and join with this and the wires will come out the sleeving
My mate lent me his laser alignment gear, and left me to it!
My Build Thread
Old 27th March 2016, 06:03 PM
Suspension all tight and cycle wing brackets fitted
My Build Thread
Old 5th April 2016, 10:47 PM
Bit of an update
Front grill glued in
Got some wiring tidied up, still more to do but getting there, refitted the bulkhead to see how it fits
Fitted the fog and reverse lights
My Build Thread
Old 5th April 2016, 10:48 PM
And yes that is my garage floor paint on my tyre grrrr
Got the rear lighting wiring almost finished, surprising how much kit you need!
Fuel breather fitted
Made a dibond divider to separate the footwell from the battery
My Build Thread
Old 6th April 2016, 12:43 PM
2nd to none cracking build .
Old 19th April 2016, 10:22 PM
Cheers mate
My Build Thread
Bit more of an update,
Lifted my ride height up a bit, 5" front 6" rear, got all my camber and toe adjusted
Then checked the bump steer, to start with from ride height it full bump it was toeing in 4mm a side
After sliding the rack up a bit on the slots I've now got
0mm total toe at full droop
2mm total toe at ride height
2mm total toes at full bump
Which according to my mate who lent me the lasers should be ok
Just need to put the springs back on the shocks, and get the ride height correct and then corner weight it when it's finished and double check the alignment
Next up, I've filled my iva forms out and sent them off! Woo hoo
I have been on with other bits and bobs but still got a bit to do, I need to get cracking!
My Build Thread
Old 20th April 2016, 02:56 PM
norton norton is offline
Jealous.
Has it moved under its own steam yet?
