Old 20th April 2016, 07:53 AM
So I'm already starting to get withdrawal symptoms from working on my car so I went out and took the rocker cover off and started to clean it up to re paint it. During the build and from when I painted it about 18 months ago it has got marks all over it chips and dust and I had a small oil leak and they have all be bothering me. So as iv got a bit of time waiting for my papers I thought now is the time.
https://www.flickr.com/photos/124541083@N02/
Old 20th April 2016, 08:23 AM
SteveH1 SteveH1 is offline
Another question if i may
How did you join the bonnet to the nose cone and how did hinge it all.
Old 20th April 2016, 10:02 AM
My body work came from Equinox and the nose cone and bonnet have a returned flange witch made it very easy to bolt together. For the hinges I use some Stainless steel one and bolted them to the under side of the nose cone and to the front chassis rail. All in all it works well.
Old 20th April 2016, 10:24 AM
Cheers thanks
Old 27th April 2016, 12:46 PM
So I couldn't resist any more. I just got of the phone from the DLVA and the paper work is going through and it is apparently "up stairs" with the licencing department to give a Reg number and should be back tomorrow. Anyway my next question was can I ring up on Friday to have my number and he said yes it should be there by then to give out. Happy days I might be on the road this weekend fingers crossed.
Old 27th April 2016, 12:56 PM
There was someone on here the other day saying that he had an email with the reg number on it and his local plate maker accepted this, hopefully you will be able to do the same, good luck
Old 27th April 2016, 01:08 PM
ye that was GaryT and I'm hoping the same
Old 27th April 2016, 04:19 PM
norton norton is offline
I am Jacks raging jealousy.
Old 27th April 2016, 11:41 PM
Ianr Ianr is offline
Is your dash from equinox? I am in the process of making one that looks the same as yours (but not as good).
Well done getting to where you are, I am very envious
Old 28th April 2016, 07:45 AM
No my dash is a home brew job. I'm thinking of keeping it as is for now and changing it moding it over the winter.
