Old 23rd May 2016, 12:16 PM
garyt garyt is offline
sounds like not a lot of choice on the alloy nose going by the replies and I know you wouldn't want to disappoint us all.... would you I'm sure it will be a tough nut to crack but boy will it look the mutts wotsits when done
Old 7th June 2016, 10:12 PM
robj robj is offline
Made a bit more progress over the last couple of weeks.
Done a bit more work on my bulkhead need to get some dome head bolts to finish it off. Also finished the support for the front edge of the bonnet/ nosecone.
Also made a press for louvers so started work on a under tray for the engine bay. Needs a lot of finishing but not to bad for a first atempt.
Old 7th June 2016, 10:13 PM
I'll get some more pics up shortly.
Old 7th June 2016, 10:43 PM
SteveH1 SteveH1 is offline
Ohhh thats nice. Any more info on how u made the press and how it works
Lookin good
Old 7th June 2016, 11:04 PM
Its not as fancy as some presses I've seen, its only made of mild steel so I have to cut a slot first don't thick it's up to cuttting the metal as well. I just tap it with a hammer to press the shape seems to work ok. I made it from 12mm plate cut on the band saw at work and welded the bits together. Took a lot of trial and error to get the fit right for the socket I kept crushing the sheet.
Old 8th June 2016, 07:48 AM
Cool seems to do the job though.
What do u do for a living
Old 8th June 2016, 07:49 AM
RichardH RichardH is offline
your definitely not getting to put a fibreglass nose on that now
Old 8th June 2016, 08:23 AM
Totally agree with the previous post, you have now set the bench mark for body work and a fibreglass nose just won't make the grade. Joking aside your body work is stunning but I know that an ally nose cone would be an absolute nightmare to fabricate.
keep up the stunning work
arfon
Old 9th June 2016, 11:27 AM
sorry but I have to agree with everyone ... You just can not put a fibreglass nose on there now, yes it will be tough but think of the end result.
I really take my hat off as the craftsmanship is simply outstanding. The attention to detail is very impressive I mean how easy would it have been to simply put the cushioning rubber in a strip but no you did it your way and it really looks good, its the little touches that really take the work up another level.
Keep at it
Old 18th September 2016, 09:12 AM
thought its about time I got moving again so it loading up time to get it home.
And back in the messy garage needs a good sort out.
