Old 11th June 2016, 01:52 AM
Mking Mking is offline
Build looks great and good to see a build coming along in my neck of the woods. I look forward to seeing it progress.
Matt King
Total spent: £0
Achieving an ambition
Old 11th June 2016, 06:55 AM
RichardH RichardH is offline
cheers matt need to catch up sometime, i am just over the bridge in dalgety bay.
there is a completed car in balerno, i asked the guy for a look/run in the car but he never replied after that.
Old 11th June 2016, 12:44 PM
rpjg1975 rpjg1975 is offline
Word of warning.....before fully welding the cross bar it might be worth bolting the roll bar down...I tacked mine then removed it to fully weld and found it had warped....
Old 11th June 2016, 03:10 PM
yep i bolted the plates down, welded the hopp to the plates, then welded the harness bar in place. removed it then to weld the threaded bits for the harness and it still moved a bit, only a couple of mm though so not too bad
Old 11th June 2016, 03:35 PM
Great, I look forward to it.
Matt King
Total spent: £0
Old 11th June 2016, 06:18 PM
seats and roll bar in today, need to figure out the two diagonals now
Old 13th June 2016, 11:58 AM
well i did a few hours on the wiring loom last night, i can now turn the key and get milage on the dash and crank the engine over, very tempted to go get some fuel but i will resist as theres welding to be done around the tank area yet.
Old 13th June 2016, 12:24 PM
garyout garyout is offline
Hi Richard good to see your recovering well from op and your cracking on with your build. The one thing I'm not looking forward to doing is the wiring
Gary
Old 13th June 2016, 02:25 PM
Dave F's Avatar
Dave F Dave F is offline
Where did you get your seats?
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 13th June 2016, 03:59 PM
the seats came from ebay, kitbitdirect i think, just search kit car seats
