Old 10th January 2017, 07:48 PM
dean211277's Avatar
dean211277 dean211277 is offline
Default VIN plate
Hi,
I have my VIN number from the DVLA so now want to stamp it on some plate and welding it to my chassis.
Two questions.
1. I have use of some metal stamps at work however they are quite big they are about 10mm high letters do you think that's going to be to big? I have read there is a minimum size but not a maximum.
2. Where is best to put it so it can be seen easily? I was thinking of having two, one in the passenger compartment and one in the engine bay
Cheers Dean
Old 12th January 2017, 10:58 PM
Ianr Ianr is offline
Size is not an issue (despite what some may say ;-) ) . It has to be able to be read from the front offside of the car. I stamped the number into two places, the top offside rail and the engine mount area. Then I fitted the car sides and the top rail number was covered - next I fitted an MX5 engine where I had previously had a Pinto engine. The new engine mount covered the stamped in number. I gave up. I stamped up a piece of 25 x 3 mm steel with 20 mm high numbers and waited until the end of the build and then welded it in a prominent position by the brake master cylinder - sorted!
Old 13th January 2017, 04:57 PM
garyt garyt is offline
There was a guy on eBay doing them I got from him and welded to the top of br9 and iva happy with that
Old 15th January 2017, 09:36 AM
DavidW DavidW is offline
I was looking for the same.
Found this guy on flea bay
http://www.ebay.co.uk/itm/Engine-Pla...AOSwB09YLF9 u
I recall someone on here made them but i cant find the post.
Old 17th January 2017, 02:08 PM
dean211277's Avatar
Thank you for the advice.
I have downloaded the IVA manual but I was slightly confused ( not difficult with me )
Thanks for the eBay link think I will order a couple of those.
